Hi, i had few RC models but i never build some model, i decide so i start my project of air catamaran to carry waterproof camera, i try make my construction simple, easy to build and cheap.
This is my idea:
Floats are made from XPS polystyren, later i reinforce the floats by laminate or something like it.
Box for motor and electronic is from gray tube for water, it can be easy cut and stick. Is possibly tu buy waterproof cower .... sure and its really cheap material
connection to floats and box will be made from alluminium.
Electronics, i choose electronict but i think somebody with more experience can choose better and cheaper option.
I need so airboat battery can work more than one hour. Is possible calculate how long battery going to work?
I want every parts from one shop because shipping price.
radio
http://www.rc-profimodel.com/en-detail-52933-devo-4-4-channel-mode-1.html
charger
http://www.profimodel.cz/cz-detail-25193-eq-start-230v-nabijec-2-3-li-poly-li-fe.html
motor
http://www.profimodel.cz/cz-detail-25520-ray-cd2830-09-cd-rom-brushless-motor.html
regulator
http://www.profimodel.cz/cz-detail-38633-ray-r-20b-stridavy-regulator-20a-s-bec.html
servo
http://www.rc-profimodel.com/en-detail-23375-hs-311-eco-bulk-s-prislusenstvim.html
Acumulator
http://www.rc-profimodel.com/en-detail-25611-g3-ray-li-pol-1200mah-7-4-30-60c-air-pack-8-9wh.html
propeller
http://www.rc-profimodel.com/en-detail-44990-vrtule-gws-ep-7x3-5-cerna-3-lista.html¨
more important stuff
servoconector http://www.profimodel.cz/cz-detail-27653-jr110-prodluzovaci-kabel-15cm-jr.html
lever for rudder
http://www.profimodel.cz/cz-detail-44057-2210-paka-mala-kratka-otvor-prumer-1mm.html
need i any more conectors for other conection or i could use melting-iron
plans how i imagine the airboat
color for fun View attachment 14731
Thanks for any ideas i like some cheaper or better ideas for my airboat.
This is my idea:
radio
charger
motor
regulator
servo
Acumulator
propeller
lever for rudder
