Align 450 Pro V2 Build Guide Part 6 Motor, ESC, Tail Servo & Gear Mesh
Finally we are starting to put more than servos onto this helicopter. In this video I will show you how to not only put in the motor, but also how to set the gear mesh as well. Enjoy the video.
http://youtu.be/87TLjorbER8
breeze400
Spagetti Pilot
Looking great Tony. On my main shaft on the 600, There is a collure that slided down from the top. You pull up on the main shaft, slide the collure down and set the set screws in. thats what holds the shaft up. Not sure if thats how your's is but! I don't remember any shims underneath.
The old versions had the little collet that you would slide down. The Pro, Pro v2 and the Sport v2 all use a shaft that has the collet built in. There is no adjustment. If it's loose, it's the shims that take it out. If it's tight, well you will see in the next video what I had to do lol.
Yeah, this is the first main shaft that you were talking about...
This is the one that is on the ones listed above...
