coolgabsi
Super Mod & DEAL KING!
700e V2 maidened!!! - YouTube
Ok so here is my full setup:
700e V2 frame with kde motor mount and metal nose upgrade.
RC booya canopy mounts. (Needed for this size)
"Hardened" align tt gears
V2 tail grips (align upgrade.. Non stock)
Edge-713mm main blades, and I think 105 edge tails
Align ds610 cyclic metal horns, and futaba 9256 tail.
MSH Brain running without auto level and with governor and 2 JR DSMX satellites hooked to it
Castle ESC ICE2HV 160.
YGE cap pack -7 for esr reduction (battery wires are more that 12inches in length... Smoothens the ripple)
Scorpion 4035-560KV motor with slant gear 12 tooth pinion. (Main gear is also hardened align 112t)
Hyperion 3800mah Life reciever pack
Batteries used in this flight: 5200 12s spyder pack (2x6s) with all EC5 connectors
What did I think of it:
It's a beauty! Just love how it just hangs. Definitely heavy!! Very heavy and I feel it in the air too. Gotta get my CoG right... It was definitely tail heavy.
The msh brain system is genius! I didn't need to tweak anything on cyclic. It's like it knew how much gain and all I need. Just awesome. Tail gain needed to be brought down.
Governor and esc aren't getting alone well enough yet. The esc I think take over soft start and then when it does go away governor applies all its force to bump the throttle up and then wags down slow. Have some issue of hunting at 1800 rpm normal mode.
In 1900 rpm mode, the governor hunts less
And 2100 idle up2 ... It's a beauty.. No hunting.. Just pure plain flying. Will have to reprogram a couple settings in the esc and make sure all is good in the governor.
But that's it!!! it was an amazing flight! So quiet .. With the helical gear system.. Blades are loud but power train is very quiet.
Forgot to take esc and motor temps after the flight but next time...
Forgot to turn the timer on stick sense on this model, so fist 2 minutes were times then, I Donno lol .. So that too next time. Lol
Hope y'all enjoy it. Got questions? Ask away!!!
