Adam
Ok so i got the bird put it the tail on put satelites on binded it setup my tx did the dir settings for the 3gx did gyro and rudder settings. Tried to maiden it sorry no vid for the problem wife was sleeping. Spooled up beutifully and when it got more head speed about to lift up it wasnt a tail wag it was a tail shake. I used sub trim trim on the rudder i had to reverse my tx. Now i noticed the screw for the tail servo horn vpibrated out. Also when it initializes the status button is suppose to be green for hh mode and it is read the cyclic is all fine except the feathering shaft bolt vibrated loose and well my knee cap caught one of the blades and now i have to order tail gears cause one stripped. There I broke a perfect bird.
