Yeah, I can't figure it out either .... I thought it was impossible to get a circuit to run if you had it upside down as the the Centre pin is +ve .....
Maybe the signal bus will fry if it gets fed backwards?
where is all the information on this issue ... I would like to do some research.
I'm an electrician by trade. Even though the positive is in the center reversing polarity will cause a back feed into the signal circuit. The problem is current flow. This will happen regardless whether it is plugged in right or not. The problem is the signal circuit cannot handle any current flow, therefore burnt up gyro channel.
The new IKon has a shunt circuit built in so if you do hook it up backwards the signal circuit is protected from current flow.
Ok regarding the pictures, I have the IKon with the slopped front. Mine came out of the box with a sticker warning to observe proper polarity or the unit could be damaged. So much for the slopped front theory. I would suggest to IKon that they put the indicators of pin position on the side of the case not the top. WTF is it on the top for anyway?
Have most of my set up done. Need to work on panel 4, panel 10 and panel 12 which is the flying style set up. How do you switch between the 3 different set ups?
Ken
Westy when will that IKon set up video be done, Lol!
3GX pin indicators are not clearly marked either, I'm pretty sure they have polarity protection because I hooked mine up wrong a couple times and no problems. Both the IKon and the 3GX the signal pin is on top and ground on the bottom. Having said that obviously it depends how its mounted so my reference to top is the side that shows the labels for each channel.
