Thanks guys,
@Stokke
It drops because, as soon as you hit TH, you need to give about -6º to keep the blades spinning. And as you approach the ground you use more elev than pitch to sow down. Like a flare, then use the pitch to finish the job. If you want to try them, just start using TH from about 2m or 5ft up and land, then progressively get higher.
Did another flight this afternoon with a bit more Smack
uploading now. Should be done by tomorrow morning
