danhampson
I've been thinking about belt lubrication for the belt on my protos, prior to the build i placed the belt in a sealey bag and sprayed it with silicone spray, leaving the belt in the silicone until fitting, I've since put a couple of flights in and the belt now looks like its never been lubed.
I've been given some silicone grease by an engineer at work for my thrust bearings and was wondering if you think it would be ok to lube the drive train with this, the initial silicon spray was an anti static measure and my thinking is that the silicon grease might last a bit longer that silicon spray and lube the drive train as well.
