I think the below settings is what you need. This is just from memory though.
Model type: Helicopter
Swash Type: 1 servo 90º (might be called Normal)
F-Mode Settings: Stunt 1 on the switch you want, and activate hold
Travel adjustments: keep everything at 100% for now. Might have to lower it if it is too much pitch and starts blowing out the tail.
Throttle curve: 0 45 75 75 75 for normal and a flat 100 for IU1
Pitch curve: 46 48 50 75 100 for normal and linear for IU1
That should be all you need to put into the Tx to get it in the air to fine tune it. You will need to do some DR/Expo settings, I would start with 70% dual rate and +35% Expo to start with. Hope this helps.
