Tony submitted a new Article:
Dx6i & Ccpm Full Setup Guide Part 1 Setting Up The Dx6i
Hello everyone. If there is one questions or suggestion that I get asked more than anything else, it's "can you make a "how to" video that covers everything from start to finish?". Well, that is exactly what I have done.
This series is going to show you exactly what to do to setup your DX6i, set all your swash, pitch, throttle curves, gyro settings, end point's, and everything else in the radio. Then, I'm going to show you exactly how to bind the Tx to the Rx. Then, setup all fo the servos on the cyclic, adjust all the links to get the proper swash height so you get the same pitch up as you do down, set the blade tracking, setup the gyro outside while hovering and getting the swash correct for FF or forward flight.
