Setups Fpv equiptment
Falcon1954
Hey guys I am going to try my hand at FPV and need some advice. I am using the Dragonlink and receiver v2 12 channel. Do I need the dragonlink OSD to go with the above setup? I will also be using the eagle eyes ground unit. I need to know what else I will need to complete the setup. Any ideas please post I am new at this. Thanks.
That is some pretty high end gear for someone just getting in to FPV.
What are you going to put it on, that makes a big difference as to what I would suggest.
Have you already got it or are you still looking.
What control system/TX do you use.
This equipment will be going into a composite Predator drone and eventually a 1/4.6 F 16 with a 200 turbine. No quad copters in this shop. Made in America no Chinese planes here. Also using a Futaba 12 channel 2.4 ghz radio. Thanks
