Trucks Granite 3s BLX motor help
StageMage
Today I went to show off my granite to my extended family, and I rocketed 6 feet and stopped. For some reason my motor just stopped working. It’s the stock granite brushless motor, and the shaft is completely locked up, not turning. Does anyone know why this happened? Do you know how/if I can fix it?
Sounds like one of the laminations in the motor came apart. Pull the motor and take off the end bell to see if there are laminations or if the wires came apart (I have had both happen with high rpm motors).
StageMage
I have no clue what I’m lookin at
Can you pull the stator out of the motor? You had said it is not spinning, so this might be a bit tough.
