Cars help. sensored brushless motor want move until manually moving the tires
chrisb1973
My associated b5m has a flash sensored brushless motor and a rs tekin speed control. when i give the transmitter throttle the esc lights are working normal but the motor want move at all until i put the tires on the tires on the ground and barely push the car foward while throttle is still applied and it takes off running perfect as always. soon as i let off the throttle it slows to a stop and then it want go again. if i am going and i let off throttle but dont let it come to a complete stop i can apply throttle and it will still run fine. if the tires stop it want run unless the tires are barely moved in the foward direction. Need help figuring this one out. anyone know?
