Quad Hung 'most' Of My Quads
I was tired of my quads sitting in a box so I decided to make up some hooks out of the wire of utility flags. One thing to note if you want to use this wire, you MUST anneal the metal otherwise the sharp angles will break the wire. Annealing steel is very easy, just heat it up red hot and allow it to cool naturally. If you shock it, you will harden it. Annealing means to make it pliable.
So after a bit of wire bending, this is what I ended up with. Not sure if I'm going to keep it this way, but it's nice to have them hanging up.
Looking good Tony. Even though you might not keep it that way, at least there together in one place vs scattered all over the place Lol.
If I do move them, I will hang them on the side of the shelf so that I can still access the helicopters and trucks. But they are in their new home.
