Trucks losi 3.4
kls23
losi sct ten 3.4 motor doesent run right just a bad motor or is there any other motors that will fit on ross dosent work ona put pull start on
EyeStation
Check that all your motor wires are in good condition. Sometimes the wires can crack in the insulation or heat shrink and you won't be able to tell without tugging on them or testing with a continuity meter of some sort. If tugging on the wire, don't yank it from the bell of the motor, just give a gentle pull and feel for stretching. If using a meter of some sort, measure the three leads, two at a time looking for a high resistance. You should see something close to a short for any combination of those three leads. If the motor has multiple strands per winding, sometimes one or two of the strands breaks and you are loosing a good % of the power for that phase.
What is your motor actually doing when you pull the throttle?
Was it running fine before the problem?
ES, this is a nitro Losi truck.
Have you spun the engine over by hand? Is there a good "pop" when it reaches the compression stroke and passes? If there is not a good pop, then you need a new piston and sleeve. These can usually run about $50 or so for the pair. If you do get a good pop (and it should be tight), then have you replaced your glow plug lately? Also, what are the stock needle settings and what settings were you running?
It's all good. There are so many variations of these things, I still have to google them and find out exactly what they are lmao.
