General Mounting Camera - Stack-x
bigone5500
This is basically directed toward @Tony. I'm not sure what frame you plan to use for the stack-x but I'm wondering how you will mount your camera? The frames I have are too wide to use the camera mount that came with them. Is there an aftermarket mount that will work with this one?
There is a mount that sells with the mini runcam that works with this one to fit a standard frame. You should be able to just shim it with 3mm shims on each side and mount it that way.
