Here is my build of the baby blender by flitetest. This build took me almost 6 hours once I started mounting and cutting the templates. The over all build was rather easy for the most part. Just make sure that the tail of the plane assembles in line with the body of the plane. Next make sure the tail is assembled square to the air frame and things will go smooth.
My goal is to make this a four channel with two ailerons vs. the single channel ailerons. I will be using a gensAce 2200 mah 25C 3S pack. My esc will be the dynum detrum 35 amp. Servos will either be T-pro mg90s or the Turnigy clones. My choice of Motor is going to be urnigy D2836/9 950KV Brushless Outrunner Motor and I am thinking of using a 10x8 prop.
babyBlender - YouTube
Motor
servos
Prop
Control Horn (not sure if these are the right ones for this plank)
Possible ESC
Need some control rods and something to make lading gear with. I was thinking a coat hanger for the landing gear. I was just looking at the parts list and it showed an 8x4e prop, was wondering how big I could go, 10x8 might be to big.
Motor
servos
Prop
Possible ESC
