Flight Controllers Omnibus F4v2 Problem Arming
OK, I've been using Omnibus F4 V2 FC for awhile now. Recently on my 210 the USB port connector on the FC broke. I finally got around to change it out with another new Omnibus F4 V2 FC. Well this time, for some reason I can't get the FC to arm with my switch. I've tried everything and nothing seem to work even though my 180 has the same FC and set up the same way. I haven't done anything different or changed anything on the FC setup or the TX setup. In the past I haven't had any problem with these FC and been very pleased with them til now. I tried different firmware and still nothing. Everything else works fine like the receiver tab, motor tab and mode tabs but still can't arm with switch. Has me baffle since I didn't do anything beside change out FC. I'm thinking the FC is no good. Any ideas will be appreciated. I'm not a happy camper :eek:!
Are you trying to arm it while it's still plugged into the computer? Some FC's won't arm when they see a USB connection. Also, make sure you are seeing an absolute bottom value on throttle before trying to arm. They won't arm with any throttle.
Hey there Tony. I have unplugged the quad from the computer and absolute zero or bottom value on the throttle. I just can't figure it out since I've been using these FC for awhile now and had no problem with them beside the one I sent you. Funny thing is if I hold the throttle stick to the far right or left and while holding it there, then flip the switch, the quad will arm.
Try lowering your throttle subtrim a few points. I will bet it's not low enough if doing that will allow you to arm it.
I just remember that issue poking it's head up on about every other FC that I work on lmao.
