I was doing some test fitting last night and found an error on the tail. When you put the rudder over the elevator, where it sits in the curved hole of the rudder is too low. The front of the notch in the rudder needs to stay the same, but the back needs to go up about 3/16". I will be notating this on the plans today. If you want to redownload them and just print out the last sheet, you can. Gotta love a work in progress lmao.
