That's right, the RCH Trainer has seen the sky once again! Thanks to Travis (RCD), I have a brand new motor on the trainer that pulls this plane around like it's nothing. I had to jump up in prop size just to take advantage of this added power.
I'm still using the 2200mah 3s battery and 3 9g plastic cheap servos. I'm still working on the CoG but I think the air foil I'm running has a lot to do with the way it's acting. I would just replace the wing, but I have way too many hours into that wing with all of the lights lol. Yes, I will be doing a night flight shortly.
The plane flys like it was never put up. adn when I say put up, I mean it. For over a year it has hung from the ceiling upside down. This has forced dihedral into the wings since they were unsupported. But, this makes for a crazy stable plane. Now I know what it would be like if I would have built it with dihedral lol.
I am working on the daddy to this plane as well, the Mini Telemaster. Again thanks to RCD I have a motor for that one as well. But, I need servos and another ESC to fly that one. I know I have the ESC somewhere for it, I just don't know where lol. But it will see the sky before too long.
So sit back and have a watch. The video is 15 minutes long but it's 4 videos put together over the course of a day. From the first flight with the new motor to the last flight where I run it until the battery died. All in all, it was about 8 hours of daylight but only about an hour of actual recording. But it was fun and that is what counts.
Remember, you can download this plane in the store. You have to have an account here on the forum to see the store however, but it's free to sign up, and it's free to download this plane! Full Specs Below!
Plans: Rc-Help Trainer Free Download
Motor: Alpha 450
ESC: Proton 30a
Battery: 2200mah 3s 35c (can use 20c if that is all you have)
Servos: 2 Dynam 9g plastic gears and one T-Pro 9g
Control Horns: Dubro
Hope you enjoy!
http://youtu.be/KQ1zdNRJXS0
Motor: Alpha 450
ESC: Proton 30a
Hope you enjoy!
