Nitro that's why I put .21 or .28Ok...
Motor = electric ... engine = nitro, gas etc...
After your other post about going back to nitro.. thought it would be important to specify since you are now mixing terms somewhat here. Motors are sometimes referred to their nitro equivalents like .21 or .28 ( cc or ci depending also ) .. I assume you meant to say engine... and that it's a CC sized one?
I got this revo 3.3 used has all servos and the opti drive and battery but no receiver or controller so I have to get that I seen them for 55.00The clutch on the 4.6 was adjustable so wheelies wasn't a problem until the wheels hit pavement or cement.
Well got this bad boy out was running fine then the idle was up and down by it self then the piston seized in cylinder.There was plenty of oil had screws set to factory guess motor was shot from the start or it was sucking air from some whereThe clutch on the 4.6 was adjustable so wheelies wasn't a problem until the wheels hit pavement or cement.
It will be good soon as I get the new motor and a few other things for itWell, that stinks & sorry to hear that. Nitro vehicles need constant maintenance. The weather, fuel mixture, and humidity are some reason is hard to get it right but when you do... it is sweet to run.
Well going through Traxxas power up program should have new motor next weekWell, that stinks & sorry to hear that. Nitro vehicles need constant maintenance. The weather, fuel mixture, and humidity are some reason is hard to get it right but when you do... it is sweet to run.
Well got new motor now was thinking of the adam drake break in what do.you guys think.Cool deal. Keep us posted on the new motor
