Well i guess it's different for all of us... yess i did lots, lots and lots of orientation hovering and flying in Sim... Lots of nose in.... and i can assure you, it saves me when i move around, still not confortable for full circuit (ok i got to admit that i'm not doing large ones, i try to master small movement, which is tougher, but when i feel it gets too far away, i bring it back nose in, i feel way more confortable nose in... why, i don't know, but i am way less nervous nose in... and i came up today at the flying field, the fact that, when nose in, you have a bigger surface to spot... when canopy is down you know your coming your way, canopy up, your going away from you, when level, there is a chance you'Re going backway a little bit, so you get the nose down a bit and bring it back.. tail in, when far away, not easy to spot if it's up, down... canopy is a bigger area to use as a reference... even with colored tail fin, rotor, it still harder to spot than the canopy...
As my first day i went to the flying field today, i found safer to spot my canopy coming my way than tail in,,, i rather see my canopy than quick give some cyclic tail down to brake... again it's different for all of us, but yeah when you get it way too far as a beginner, i really, really, don'T regret at all, all the nose in training i did and orientation in sim... but i agree side in is a bit tougher and nevrous when windy.... but with some training you get use to it.. but again, in real life and sim is difff.... in real life you have the fear factor of the heli comming your way...
But i swear to god guys... orientation does really help as a beginner... but yeah it's tough to learn.... at first you give yourself some trick to trick your mind/brain, ie, the trick i found was, when nose is... simply send the heli the way you DON'T want her to go... if she's drifting on your right (on her left) well simply give some right aileron since she is going your right.... sounds stupid but it works way better and trian your brain to react way faster than trying to analyse which side is which.... and after lots of training, now, it's became for me a reaction... i do it as reflex... when they say brain muscle training.. it does work.. now, i only got to get rid of one thing.... the fear factor of security zone... when training hovering, you get a kinda safe zone, close to you...but when starting to move around, it kinda scare the **** out of me when i kinda get too away from that zone...... when i get scare, i simply turn her so she is not side in (which doesn give a clue if shes coming your way or away) but when i turn, if shes tail in, fine, but, if shes nose in, i don'T get scared... which alows me to save some more maneuvers to bring it back.. instead of risking to lose her more while trying to turn around to get tail in, i simply correct her heading right away...
But damn flying an Heli is so much cool.... but so much hard.. i'm sure the bigger the heli, the easier it is.... a 450 can quickly get away from you and if too far eye sighting gets tough :S
