Today my first round of parts came in:
Hobbywing V4 40 amp, solid brand. While they have their quality issues I still feel a reliable brand. This will be my second V4 HW esc I hope this one goes better. This particular esc has its own rpm sensor with a pre wired lead. So if your looking for an external governor then the v4 might be the ticket.
This motor is the Lynx 2214 4100of, its the recommended motor for the OXY 3. The motor is 3S or 4S and runs a 3.17 mm shaft for the pinion. Lynx also makes a rewind or self wind kit for this motor. So if your into self winding that is available.
The blades are 50 mm which is the bigger size for lower head speeds. Lower is classified as 3500 and below. I may need to double check that figure. So the manual say what I posted already.
I will need to crunch some numbers but I think I will be going for a range of 3500 to 3700 to 4000 on head speeds. Again I will need to do some math and see. Depending on what's in the kit I will need to add some 47 mm tails to the list along with the 275 mm lynx plastic blades. Yep going to go plastic for most of my flying. I am still getting the Rotor Tech carbons but for my general stuff the plastic will be just fine and at $15 you can go wrong.
My next purchase will be 2 batteries and connectors and maybe the main blades. We shall see how things play out.
In the meantime the Neo and BK servos will be removed from the X3 for now. I really can't see spending the money on servos and FBL when I have them sitting around. In the near future I will be getting the lynx kst servos and possible setting up the kbar for the vcontrol. My goal is low cost and recycle as much as I can.
