Sam Mitchell
So i purchased a brand new Tmaxx Engine 3.3 and a 2.5 transmission. During the break in around the 4th tank when you go full throttle the motor would bog down real hard and id let off and it would idle normal. I Tried leaning it a little bit, still the problem exist. I began questioning if my Transmission had anything to do with it idk. But anyways i am running a RD logic's dual exhaust on it. Idk if that has anything to do with it. Carb gets good fuel. Glow plug is fine. No sign of lost compression all gaskets are present. Like i said motor is brand new. I need help with this i can not figure out whats wrong with my truck.
