Hey guys,
thanks for the kind comments on my video, I found this place through the insight page on my youtube video
To answer a couple of questions; a standard 91 engine puts out around 3.5hp, the wren44 turbine engine puts out 6.8hp
So it is quite a bit more powerful than stock. This is at the cost of a significant weight penalty, however we built it as light as possible - HV servo's so no regulator, 3ch sbus receiver in to the vbar etc etc. It's an awesome bit of kit
The starting question can be answered with this video:
<iframe width="640" height="390" src="http://www.youtube.com/embed/xBl9JuNdp-4" frameborder="0" allowfullscreen></iframe>
At the beggining you can see the screen displaying trim low. this is a safety feature to prevent accidental starting. The trim is then raised, giving it the ready. Then a simple full throttle and back to idle on the collective stick tells the engine to start. This is full auto on this engine/ECU. It first opens the propane gas valve and ignites the glow, then spins the engine over with a bendix starter on the front. Once it reaches the required exhaust temperature (somewhere around 500 degrees c i think),it then starts to pump jet A1 fuel in and begins the switch over to raw fuel. The rpm then increases to around 55'000 and idle. It then hands throttle control over to the rx input. Full power is a maximum of 195'000rpm, although with the gear ratio on the 700 it is only able to reach around 170'000 and as such, is down on power a bit. When you shut it down (trim back down at idle), it then spins the starter over again for a second or two at a time, to suck cold air through the engine and cool it down to below 100 degrees c.
Hope that answered a few questions
You may also like the video of our Synergy N9 Turbine with Opti-Smoke
<iframe width="640" height="390" src="http://www.youtube.com/embed/W0iPke2WtYc" frameborder="0" allowfullscreen></iframe>
