Thanks to mountaindewdude76 (I'm so going to change his name, it's too friggin long lmao), I was able to test, and now own my very first watt meter. Not only is this a power meter for motors, but it's also used to check the servos and what kind of power they are pulling. Needless to say, this meter can and will come in very handy. I may not need it every day, but when you do need it, it's very nice to have.
The Turnigy Power Meter, as stated above is used to test the power draw of motors and servos. On Channel 1, you can test the servos. There is a max 8.4vDC and 10a on channel 1 for the servos. On channel 2, there is a max limit of 60vDC and 100a. Needless to say, it should handle everything I have laying around here.
I started off soldering the plugs onto the wires since it doesn't come with any. Once that was done, I grabbed the only plane that I had ready and connected to my DX8, the Edge 540 Mini.
I start out by plugging in and testing the motor. Then I test out one of the servos (left aileron to be specific). To my surprise the screen is a full color screen to an extent, but it very nice for what it is and what it costs. I was able to pull over 300w out of this little motor and I can't wait to put it on my big Edge 540T and see if I can pull some really good numbers.
If you have any questions about this meter, let me know and I will try to answer them. Hopefully most of the questions are answered in the video below. It's just too bad that I don't have more planes, or better yet, a helicopter to test this out on. In due time I guess.
Click the link below for the manual to this meter.
View attachment 885808003X365809X40.pdf
Turnigy 2in1 Power Meter, Watt Meter, Motor Tester, Servo Tester - YouTube
