General Which hinges????
Loopy
What hinges do you all prefer? The Robart or the DuBro flat hinge? I've always used the flat style, but the Robart looks to be much easier to install and there is a device that can be added to easily remove and replace for covering and finishing.:dunno:
I always used the flat hinges ... You are either cutting a slit or drilling a hole... either way you have to keep them even or level with the surface of where you use them.
