Am I right in thinking that when setting up tx for a new heli that you set up for spool up mode then set up for flight mode. Set up for spool up the throttle curve goes from zero to 100% in a linear fashion so when you move the stick to say 50% of its travel you are at 50% throttle. Then you switch over to flight mode where the throttle is set to say 80% across its full travel. Of course pitch is also set accordingly but am I missing something or reading it entirely the wrong way. Any thoughts would be most welcome.
