I was hit up on my email from a vendor asking if I wanted to do a review on YET ANOTHER cheap POS plastic quad, and I said NO! Instead I asked if they wanted to send this one and they agreed. The link to it is below if you don't believe they call it an "Interior Traversing Machine" lmao.
If this was an Eachine, it would be called the EX 110 and not the QX. I have no idea why...
Below are a couple links that you may need to get this thing going. First is a completely stock dump file that I pulled, on video, before I did anything to the quad. But before I did that, I had to install (the second link) a new driver on my computer in order for this thing to connect to the computer. It does NOT use the same drivers as the Eachine models and I have absolutely no idea why. So the first link is the stock dump file and the second link is the download link for the drivers that you will need in order to get this thing connected to the computer.
If you get this quad, or the Eachine Ex 110, you will have to put the DSM Rx into bind mode in the CLI. You can't just turn the quad on with no tx connected and expect the Rx to go into bind mode. So below is the code to use in CLI to put the Rx into bind mode and at the end where "X" is, you will use one of the numbers listed below the code. Remember, use the one that is meant for YOUR RECEIVER! If you don't you could have issues. If you have any questions about how to do this, or you would like me to make a video about it, post up and let me know.
set spektrum_sat_bind=X
3 for DSM2 1024bit/22ms
5 for DSM2 2048bit/11ms default AlienWii32
7 for DSMX 1024bit/22ms used by Devo 7e
8 for DSMX 2048bit/22ms Used by new DXe
9 for DSMX 2048bit/11ms
Drivers - http://www.silabs.com/Support Documents/Software/CP210x_Windows_Drivers.zip
QX 110 Stock Dump File - View attachment QX 110 Stock Dump File.txt
And here is the video on the review. I was going to make multiple shorter videos, but it's the same stuff that I have done with all of the Eachine boards and quads including the BeeCore as well. so I just lumped it into one video. Sorry for it being so long...
Click The Link Below To Check Out This Quad
Interior Traversing Machine QX110 110mm Micro FPV Racing Drone Quadcopter With F3 Flight Control
This video will be live at noon (about 11.5 hours from the time of this post). I needed the link lol.
