Spektrum 3GX + Ar8000 + Tm1000 / Short Question
4Pete2Fly
Just want to make sure that I have this right before final wiring.
· External power into batt/bind port of 3GX
· Batt port out on 3GX to Aux 3 on AR8000
· Bind/data port out on the AR8000 to the TM1000
Will this work & my understanding with this setup not/never hook satellites to the 3GX unit.
This is going on a T-Rex 700 & the reason was to have an open channel to activate a switch to open bay doors on a box that will be mounted on the underside of the body between the skids. The box will be used firstly to spread some of my dad’s ashes in remote wilderness area as requested (by air only). After that it will be used for a flyby dumping such items as confetti or colored sparkles.
All my other DFC helis are only using 2 satellites only off the 3GX.
Thanks for looking!
Pete :lemo:
That sounds like it should work. It's what I would do to start off anyway.
And awesome idea for your dad. Sorry for your loss. I lost mine when I was 12.
4Pete2Fly
Thanks for the answer to my question & sorry to the 2 of you that lost your dad at an early age, I should be blessed that I had him for 62 years.
Take care
Pete
No apology needed. If you have any other questions, all you have to do is ask. We are here to help. And, if you can, I would love to see video of you doing what you stated above. Talk about a fantastic tribute!
