DAL2855
Banned
I am in need of a 5mm diameter pinion for my 550. I thought my motor had a 6mm shaft but it turns out it has the 5mm shaft. I would be willing to swap this 16T straight cut pinion for a 5mm 11-12T pinion! If you have one please let me know!
Ordered from HeliDirect! 11T and 12T pinions! According to HS Calculator, it should be right around a 2000 RPM headspeed with gov store enabled in the YEP 100a ESC!
