heliman uk
Hi I am setting up a align 450 se v2 heli with satalites, I have put 8 deg + pitch but unsure howe mutch negative to give this is my first time setting up flybarless any help would be appreciated,
hey there heilman. I set all my birds at 9+ and 9- and works out well for what I do.Hi I am setting up a align 450 se v2 heli with satalites, I have put 8 deg + pitch but unsure howe mutch negative to give this is my first time setting up flybarless any help would be appreciated,
That's what I'm talking about. My self I like my helis around 13+/-I set all my birds at 9+ and 9- and works out well for what I do.
HI D,o,g Thanks for your reply , yes i was thinking same but dont want heli to come down as fast as it goes up .What's up heliman. I can't speak for other but my self I like equal +/- pitch on my heli. I've heard that 10 degs is a good starting pitch to start but some have different readings like +8/-6. Just my![]()
right D.O.G, both of my curves are straight at 9and9 and works great for no more than I do in normal mode only.In that case in the TX under the pitch curves I have my set to:
N= 46/48/50/75/100
1=0/25/50/75/100
2=0/25/50/75/100
that's what I have and as for throttle curves I run a straight curve. This is a spektrum TX I'm using.
Hey there murankar I'm going up my pitch to 12 on my 600 nitro and see how she goes.Everyone has there likings when it comes to overall pitch. Personally in the past I found anything under 11 degrees lethargic. Most of my helies are around 13 degrees. If your just starting out I would shoot for +/- 11 dergrees. Ensure they are both the same. as long as your with in .1 you should be good to go.
yeah tell about it. It came down about an hour ago. Going to order parts now and when I get rebuilt going back 9 and 9.With nitro you really need to watch pitch. You'll want to mess around with head speed and pitch at the same time to get it feeling right. To much pitch and you'll bog the engine.
hi buel williams I have pressed something and its saying I am ignoring your content, but i dont know how to correct it, please accept my appolagies for this matter,yeah tell about it. It came down about an hour ago. Going to order parts now and when I get rebuilt going back 9 and 9.
