Well the waiting is over! I finally got,my hand on the 450 Pro that has been sitting hidden somewhere in my wife's wardrobe for the last 6 weeks. It's been an ordeal and a trial of patience.
Anyway I intended to do a full build log, however apart from a few bits last night I have pretty much built it today.
I'll attach a few photos of key stages.
The build itself was very straight forward, the quality of the Align kit is amazing.
A heli loving friend very kindly gave me a DFC conversion kit so that was incorporated in to the build.
I have run most,of my wiring internally, and could have done with slightly longer servo leads, likewise the supplied signal wires for the 3 GX were a bit on the short side.
I have mounted my 3GX in the upper position, and I am using a Spektrum AR6210 and satellite, with the main Rx mounted in the alternate giro position.
The only grumbles I have are:
Plastic ball link connectors for the DFC arms were an absolute pig to start on the threads. I may replace these as I'm not too confident they won't strip out.
The canopy fouls the main gear on the left side.
No torx key supplied for,the main blade screws.
All that's left is,to connect the rudder servo arm to the tail pitch slider, then set everything up.
Oh and work out why my 3 GX won't connect to the software on my PC!
My apologies for the random selection. I got carried away with the building and didn't take as a many pictures as originally intended.
And they won't appear in the order I uploaded them!
I will be repositioning the satellite so that the antennae are in the vertical plane
