blade 450 pushrod lengths
What one is this? The 450x or the 4503D or what? I'm not sure on all of the 450 brands, but I just want to make sure I'm getting you the correct instructions.
Left swash link: 55.75 mm
Front swash link: 49.75 mm
Right swash link: 44 mm
Swash to main blades: 61.5 mm
Hope this helps.
hi tony where do you measure to and from on links thanks geoff and they are the ones for the blade 4503d thanks geoff
Geoff, remember that the lengths offered by Tony are starting points, they will vary as you set up the heli.
