Not sure on the balance weight of the batteries yet but my v911 could use some forward momentum. Yes it bind right up to the v911 trans. no prob. works with my FS-t6 but will not hole a bind, have to do it everytime you switch the heli off.
Woody
Can't fly today too cold for me and the V912 outside. Plastic breaks way too easy at 7 Deg F and Fingers and Toes get too damn cold too. . The build quality of the v912 is impressive to me compared to the V911. All metal frame, metal skids heavy metal Flybar. The gears on the Main rotor and the Gear drive assy on the tail rotor are kinda noisy. Put a couple of drops of Trinity Rev tech Drops on it and it quiet right down. It does have a bit of a vibration when the rotors are turning. maybe needs some fin tuning to balance things out. The one thing I absolutely do no like is the way the canopy attaches. the sides are fine, press on studs like normal. but the bottom uses a long narrow slot with two tabs at each end. and you basically have to use a flat screwdriver to remove it from the tabs. I can see this as a major fail point on the canopy. If it does I will be add a different connector of sorts.
One thing to note is go over one with a screwdriver first. I noticed right away the tail rotor guard flopping around and found about half a dozen other screws loose from either shipping or just not tightened right. Also found one stripped out and repaired that. Other than that she looks and runs great. Just need decent weather to fly her. Or maybe in the warehouse at work tomorrow....hmmmm.
Woody
