Harford
Further to my post 24 Feb. I have a further question please. If I look of the Microbeast website, there is an explanation about how to connect the SP4651T to the MB. This involves (as I understand it) the connector which comes with the 4651T plugged into the side of the MB, but necessitates changing the wiring on the plug to effect a polarity change. Quite challenging with such a small plug ! I had understood from the previous correspondence that I could using the SRXL2 adapter cable, which I assumed is the same cable from Spirit Systems I have used in the past to connect a 4651T to a Spirit unit. Is this correct and if yes, can you please explain how I connect this adapter to the MB. Many thanks
