Karubah
Did a bit of damage to the 450 this arvo. First time in over a month. Confidence out weighing abilities. So here is a list of the damage.
Bent main blade link
Bent tail boom
Main blades delaminated
Battery damage, might get away with it as looks like it only broke the outer cover
Also did the gears in the pitch servo. Oh well at least I have all the parts on hand so it " REPAIR TIME"
I caused this by flying in fairly strong winds and when I went to land it just dropped from about 1 ft of the ground and the main blades hit the boom when it hit the ground. Will check feathering shaft and main shaft when I strip it down. The screws on this poor old heli are getting worn out from the number of times they have been in and out.
Bent tail boom
