General Dummy Loads For Patch Antenna
bigone5500
How critical is it to have one on the antennas that have left and right hand polarization connections on the back? I don't have one yet for my antenna but will next week. I guess reception will suffer?
bigone5500
I just looked at the package for the one I purchased and it says 3.0 GHz 50 ohm. How will this affect a 5.8GHz system?
Basically the load is to complete a circuit. Apparently from what you are saying, both ports in the back are wired together and leaving one open will not work that well and will cause issues. I have no idea on FPV, but on Coax, like your home TV runs on or your internet, you have to run a 75Ω resistor to plug any open ports in a splitter that are not being used. If you don't, you will have signal degradation which is what I suspect is happening to your system.
Actually I was wanting to see the antenna. I had a pretty good idea what the termination end looked like lol.
