Spektrum Dx8 G2 Model Listing Error
Mark Gray
I have a question about the model listing in my DX8 G2. A designation has appeared called "UNUSEABLE MODEL" in my model listing. I did not create it. And the scroll wheel will not allow me to select it so I can delete it. It jumps from my last named model to "Add a new Model". Is there a way to correct this and remove that item? There should not be a model there.
You can try and redlash the radio with new firmware. That might delete any model you have in there. So make sure you have your other models backed up before flashing.
