450 Flybar vs DFC Piro Spins
mousie
Ok heres my question. I have two rex pro 450s, one is a flybar and the other is a DFC running the beast x. My question is when I do 360 piros my dfc wants to drift, where my flybar stays level and stable and in one spot. Is this normal with flybarless? I double checked all my setup and is right on and it hovers perfect with very little stick imput .
Slobberdog
I have found with my 450 dfc if you start the piro with a slight tilt in the rotor disc then it will drift, the flybar setup lends itself to keep that disc much flatter due to the flybar gyroscopic effect,
