My twopeneth
As an Engineer to trade I have worked with bearings all my working life. Lee is correct, repacking thrust bearings is fine.
Main shaft and tail bearings tend to be double ZZ which denotes zinc seals( classified as sealed for life, which is ambiguous, as it is bearing life and not infinity).
I have only been in this hobby 2 years and already as Lee due to vibration changed bearings out.
I have done this on all my helis a few times due to crashes and wear. The more you fly the more you wear
Like all things it comes down to maintenance and how you run these things. I have found the smaller 450 goes through more than the 600. Possibly my flying, but lately as my skills have got better they are all flying the same and the maintenance has increased.
Checking bearings can be done in position for play between the shaft and bearing or by moving the bearing between your fingers and feeling for notches or grinding. The bearing should always feel smooth to turn.
Again from a noobies point of view, without background skills this is hard to do. So back to the original question. Rule of thumb, if its not broke don't fix it. If you have play or vibration change it out. The key is remembering what it was like new, number of flights .
I have precision measuring equipment where I can measure bearing and shaft tolerances so I know its worn(the geek part of me).
Dirt ingression as Lee mentions, where he flies in dry dusty conditions is always possible, but generally misalignment, water, overheating and degradation through wear are what will kill your bearing.
Hope this helps
..........steps off pedestal
