HeliDinoRC
Senior Rc-Help Member
Well, I thought I would take the 450 3D (flybarred) out and run some batteries through to make sure my skills were adequate after the winter to maiden the Goblin. My preflight check of servo travel direction and gyro correction checked out great. I fired her up and took off. I got into a nice hover and got my bearings and began to throttle up a bit and all of the sudden she tilted forward. I tried to correct and gave some back cyclic. This didn't work and I watched the bird continue to tilt forward and WHAM! Nose first into the dirt.
Back on the bench, I removed the blades and tested the servo and gyro direction. Everything moved in the correct direction. When I gave it some throttle to spin it up I noticed the elevator arm moving up and down sporadically. As I continued to throttle up the movement intensified and just over half throttle the arm moved in the full down, or full forward, position. I tried to correct with no avail................I think I know why I crashed!
A little background: I just finished setting the head up last night and replacing the gyro with a Futaba GY520 (nice 450 gyro BTW) as the stock G210 was giving me massive jittery, tail wag no matter where I put the gain. I got the swash mix perfect and Bench test resulted in correct travel of all servos and gyro correction; however, I did not spool it up last night.
See the video........is the servo supposed to move like this with no elevator input from the Tx???????? I would think all cyclic servos should remain steady???
I did some further testing by programming a throttle curve of 30-30-30-30-30 on IU2. I then throttled up in Normal and flipped to IU2 and the servo moves to the full down position (tilts the swash full forward). The elevator servo does not react to my Tx inputs.
[video=youtube_share;msDN_h7B9Gs]http://youtu.be/msDN_h7B9Gs[/video]
