Misc. Gyro
sneezy007
Hi everyone,
I installed a Hobby Eagle A3S3 gyro in my Eflite Pulse airplane. When I activate the gyro, all the control surfaces are correcting in the proper direction except for the left aileron. I've gone in and reversed it in the gyro and it's still not right. My ailerons are in plugged into two separate channels. I'm scratching my head on this one. Has anyone experienced this before?
Thanks,
Dino
Only thing I can think of is to go into that channel and maybe reverse it in the Tx and see if that helps.... I'm reaching here as reversing in the gyro should have worked.
I'd also double check that you setup the gyro for two aileron channels and not just one. I assume you have but it doesn't hurt to mention it just in case.
