Help with Sound card using a Futaba 14SD throttle set up
Pheonix
Can anyone help with setting up my throttle for the sound card using a Futaba 14SD on a P51 by Freewing. I am trying to sync the throttle with the sound card. I do not want sound when the throttle is in the full down position but only after I advanced the throttle. I tired to do so by using the trim tab; however this does not work. I would appreciate any suggestions anyone might have. Many thanks.
Major
Hi Major,
Welcome to the forum :)
As this is the Member intro forum, people don't come in here to answer questions.
Use this section just to tell use a bit about yourself.
For more help with your problem, post in the Transmitter section.
Don't know of any one that has this system, but you never know.
Cheers Lee
