Boats I built it for nitro but
Fly-n-Low
It is a super light 40 size mono. The deck came off one mono and the hull from another. I built it when I was working for Youngblood. I built so many monos I couldn't count them all, and this is the only one I have... Plus the hydro.
So I was thinking about electric... Although it is rigged for a nitro motor....
Wow that is crazy! I was pissed because the mono pic didn't show, so I posted one of my hydro...
That is one of Jim Youngblood's race boats. You can see a repair on the left sponson. This boat is full composite.
SOOOOOOOOOOO here we GOOOOOOOO!
Rare bird! ............ Way back machine... Huge old analog servos... Throttle, mixture, and the rudder servo is huge! WOW!
I'll have to open it up and take more pics...
I know it looks rough, but it was hanging on the wall in a friend's shop that passed away. His widow gave it to me. It was originally one of Jim Youngblood's race boats. Tidewater Engineering made all of the hardware.
I have to check the motor out, looks pretty dry.... Nipple on the pipe is MIA. I'm going to try to get it going. Should be fun! I remember watching Jim run them... even ran a chase boat for their practice sessions.
Talk about side tracked... I have a attention span of a gnat! I don't know, I had a Picco 45 that was supposed to go in it. Where it went???
Like I said, I built all of Jim's monos that he sold at one time. I knew how to split the mat to get the weight down... and to use the least about of resin. Build several custom boats and I was pretty good at mixing custom gel colors! All we had was black, white, yellow, red, and blue. If you wanted purple with a lime green stripe, I could do it though. Crazy the requests we received. I wish I would have had a phone cam back then.
The blue mono is a one of. Even the motor mount has been cut down. Maybe I need to stick with nitro... that is what is was built for.
More of the insides. The old man was meticulous to say the least. When I was building his boats, he watched over me like a hawk, until he trusted I did it HIS WAY! I miss the old fart.
I did spin the motor over... Seems to have nice compression. I need a belt. I have some plane, heli, and car fuel... but when I was running boats.... I needed at least 60% nitro if I remember right.... Water cooled is a huge factor.
This was one of his projects... a two stroke gas motor. You can see all the the molds in the back ground. Not sure where the molds went, but too bad... I can build every one of them in my sleep!
This was way before electric power.
More rambling about Jim Youngblood ... But he designed and built this, and I later restored it. TX 18 as it was called. I was a river rat back then! Bare hull was 350#. Total was 1,100 maybe? And that ain't no 150. Probably more like 250...
