Hello
Am now working on the tail servo setting
I have a doubt in regard to the setting for tail servo I have tail servo horn 90 my doubt is do I suppose tail blade be Zero pitch ??
I was using this same servo with 3GX and I did zero pitch on tail blade at that time
but now with iKON I notice that push rod was making the servo binding an in software I keep adjusting the throw as all time it was an increment of 1 or 2 units on tail slider on step 4 with no reason
what I did now is enter the iKON menu go to step 8 go for Rate mode and seat the grips to have Zero pitch then adjust length of the push rod accord and I double check and now there is no change or increment in tail slider now its 100% equal both throws
but am not sure if the way I did this is correct
Also there is in step 8 other options that am not sure if I need to complete
Proportional Gain: I have it set it in "Is set in software "
Precompensation: I have no selection in this field
all help appreciated
Angel
Angel
