I'm puzzled
Trex 250 Flyer
Hi guys i have recently purchased a Trex 250 and i binded it to my Spektrum DXSi and it all worked how it should, the day after that i took it outside to start it up and the rotors spun and it tipped over into the ground because of the wind and now i have no control over it what so ever and it wont even make i noise when i plug the batterys in so can someone please, please help me out thankyou.
I would check all of your plugs in the Rx and make sure they are secured. Check all of your wires actually and make sure none of them are broke.
Also, if you are using the DX6i (I'm not sure if it was a mis type or if I'm missing something), make sure the light on the Rx is solid when you plug it in. If it's not, then you may need to rebind the Rx to the Tx.
