Batteries LiPo Life Expectancy
Those Groupner chargers seem to be rare beasts in the UK. Most high end setups here use Powerlab or iCharger. The Groupner looks to be a very high end product and lots of high tech features. If I read the spec right it's got dual 400W / 20A outputs?.. That will get the job done nicely. You can hook up a parallel board on each output channel and then charge 4 batteries on each board at 20A which is a 1C charge rate for 4 x 5000mAh batteries. That would see all 8 bateries fully charged in less than 1 hour.
