sarconastic
I have a simple question. the bolts that shipped with my Hausler 450 for the main blades when installed into the Nylock nuts just barely screw into the nylon parts of the nut. Not liking the length, I feel they should be more into the nylon. If I snug them down to what I think is too tight for the blades then they will protrude just a little past the nylon. I am wondering if I got too shot of bolts or if the blades I got are too think maybe. If some one could measure the length of their bolts from inside the head to the tip with a caliper and even the thickness of the main blade that slides inside the blade holder. I would appreciate it. I can use lock tight on the nut of course but it still makes me nervous.
Also on the Jesus bolt for the under side of the gears the instructions says tighten the nylon insert nut. It did not come with a Nylock but, Should I replace this one or just use a lot of locktight here as well.
thanks
Woody
thanks
Woody
