That or a spider type will work fine. I use that board too for bigger batteries.. but for my 130x I had just gotten a parallel spider connector for the batteries .. ( I sold all mine..) I actually had converted the bird to micro deans so I converted my slider parallel charging connectors to deans too
You can make one yourself just as easily.. But readymade ones are available on a particular website..
The paraboard what lee pointed in that pic will not work with 130 batteries because if you are keeping the 130 batteries at stock connector, you don't have the main charging wires (something to go into the banana plug on a normal charger) .. You just have the balance (3 pin) port on the batteries for charge and draw.
Ill post a link for something that will work with 130 batteries.
I have a two battery parallel charger for blade 130 stock batteries lying around (forgot I had it).. If someone wants it, pay the shipping and its yours..
You want that.. I can ship it to you.. But you being in Wales.. might be better getting yours orderd from a website.. you can then get more parallel legs from them.. Ill post a link...
-------------------------------------EDITED-----------------------------------------------
After I was declared drunk
Fly safe!!
have fun!
