Raptor X50 converted to electric **HELP**
scale_operator
So I have a raptor x50 that I converted to electric. I kept the clutch and its stock gearing, 10/85. I'm running the RCA 5-blade head with 105g scale blades, CC 120HV, Scorpion 4025-550, 20A CC bec, 22.2V 3300 meh x2, and an Ikon for stabilization. After 8 min flight the esc and motor are blazing hot. Data shows 28.4A max at 1400 rpms, 177°f. Common sense tells me my stuffs not supposed to be that hot. Also as I give her throttle the tail wags super bad from left to right. Any help appreciated.
Thanks for the reply guys.
Eye station-they have a gear set that is 11/96. I was told that would work good with 6s. Should I try it anyways? How do you think I should re-gear this, up/down pinion/main?
